The following code creates a TextField widget and a RenderTable with a single Rendition. Note that both the XmNlayoutAttrObject and XmNlayoutModifier pseudo resources have been left unspecified and therefore defaults to NULL. This means the LayoutObject associated with the Rendition is the default locale's, if one exists.
For this example to work properly, the locale must be set to one whose codeset is ISO 8859-6 and whose locale-specific layout module can support the IMPLICIT_BASIC algorithm. It then modifies the Rendition's LayoutObject's ImplicitAlg value via the Rendition's XmNlayoutModifier pseudo resource.
int n;
Arg args[10];
Widget w;
XmRendition rendition;
XmStringTag renditionTag;
XmRenderTable renderTable;
w = XmCreateTextField(parent, "text field", args, 0);
n = 0;
XtSetArg(args[n], XmNfontName, "-*-*-medium-r-normal-*-24-*-*-*-*-*-*-*");
n++;
XtSetArg(args[n], XmNfontType, XmFONT_IS_XOC); n++;
renditionTag = (XmStringTag) "ArabicShaped";
rendition = XmRenditionCreate(w, renditionTag, args, n);
renderTable =
XmRenderTableAddRenditions(NULL, &rendition, 1, XmREPLACE_MERGE);
XtVaSetValues(w, XmNrenderTable, renderTable, NULL);
n = 0;
XtSetArg(args[n], XmNlayoutModifier, "@ls implicitalg=basic");
n++;
XmRenditionUpdate(rendition, args, n);
