To switch into table lookup input method input mode, type <Compose> <l> <l> from your current input mode. The input mode is displayed at the left bottom corner of your GUI application.
Once you turn on the input mode, there is a lookup window showing multiple candidates of Unicode characters. You can choose any one of the candidates by moving your pointer and clicking the left button on your mouse. You can also select any one of the candidates by choosing a left-hand- side letter associated with each of the candidates.
Once you are finished using the current input mode, you can switch into other input mode by typing corresponding input mode switch key sequence.
