x86 Assembly Language Reference Manual
ELF Header
The ELF header is always located at the beginning of the ELF file. It describes the ELF file organization and contains the actual sizes of the object file control structures.
The ELF header consists of the following fields, or members, some have the value 0 for relocatable files:
e_ident
This is a byte array consisting of the EI_NIDENT initial bytes of the ELF header, where EI_NIDENT is a name for 16. The elements of this array mark the file as an ELF object file and provide machine-independent data that can be used to decode and interpret the file's contents.
e_type
Identifies the object file type. A value of 1, that has the name ET_REL, specifies a relocatable file. Table 3-1 describes all the object file types.
e_machine
Specifies the required architecture for an individual file. A value of 3, that has the name EM_386, specifies Intel 80386. EM_486, specifies Intel 80486.
e_version
Identifies the version of this object file's format. This field should have the current version number, named EV_CURRENT.
e_entry
Virtual address where the process is to start. A value of 0 indicates no associated entry point.
e_phoff
Program header table's file offset, in bytes. The value of 0 indicates no program header. (Relocatable files do not need a program header table.)
e_shoff
Section header table's file offset, in bytes. The value of 0 indicates no section header table. (Relocatable files must have a section header table.)
e_flag
Processor-specific flags associated with the file. For the Intel 80386, this field has value 0.
e_ehsize
ELF header's size, in bytes.
e_phentsize
Size, in bytes, of entries in the program header table. All entries are the same size. (Relocatable files do not need a program header table.)
e_phnum
Number of entries in program header table. A value of 0 indicates the file has no program header table. (Relocatable files do not need a program header table.)
e_shentsize
Size, in bytes, of the section header structure. A section header is one entry in the section header table; all entries are the same size.
e_shnum
Number of entries in section header table. A value of 0 indicates the file has no section header table. (Relocatable files must have a section header table.)
e_shstrndx
Section header table index of the entry associated with the section name string table. A value of SHN_UNDEF indicates the file does not have a section name string table.
Table 3-1 Object File Types
Type
Value
Description
none
0
No file type
rel
1
Relocatable file
exec
2
Executable file
dyn
3
Shared object file
core
4
Core file
loproc
0xff00
Processor-specific
hiproc
0xffff
Processor-specific
