The SunOS x86 assembler generates the wrong object code for some of the floating-point opcodes fsub, fsubr, fdiv, and fdivr when there are two floating register operands, and the second op destination is not the zeroth floating-point register. This error has been made to many versions of the USL UNIX® system and would probably cause problems if it were fixed.
Replace the following instructions, in column 1, with their substitutions, in column 2, for x86 platforms:
Table 2-11 Floating-point Opcodes|
fsub %st,%st(n) |
fsubr %st, %st(n) |
fsubp %st,%st(n) |
fsubrp %st, %st(n) |
fsub |
fsubr |
fsubr %st,%st(n) |
fsub %st, %st(n) |
fsubrp %st,%st(n) |
fsubp %st, %st(n) |
fsubr |
fsub |
fdiv %st,%st(n) |
fdivr %st,%st(n) |
fdivp %st,%st(n) |
fdivrp %st,%st(n) |
fdiv |
fdivr |
fdivr %st, %st(n) |
fdvir %st, %st(n) |
fdivrp %st, %st(n) |
fdivp %st, %st(n) |
fdivr |
fdiv |
