x86 Assembly Language Reference Manual
Decimal Adjust AL after Subtraction (das)
das
Operation
decimal-adjust AL -> AL
Description
Use das only after executing the form of a sub instruction that stores a two-BCD-digit byte result in the AL register. das then adjusts AL to a two-digit packed decimal result.
Example
Decimal adjust the two-BCD-digit in the AL register:
das
