SPARC Assembly Language Reference Manual
3.2.1 Section Header
The section header allows you to locate all of the file sections. An entry in a section header table contains information characterizing the data in a section.
The section header contains the following information:
addr
Address at which the first byte resides if the section appears in the memory image of a process; the default value is 0.
addralign
Aligns the address if a section has an address alignment constraint; for example, if a section contains a double-word, the entire section must be ensured double-word alignment. Only 0 and positive integral powers of 2 are currently allowed. A value of 0 or 1 indicates no address alignment constraints.
entsize
Size in bytes for entries in fixed-size tables such as the symbol table.
flags
One-bit descriptions of section attributes. Table 3-2Table 3-2 describes the section attribute flags.
Table 3-2
Flag
Default Value
Description
SHF_WRITE
0x1
Contains data that is writable during process execution.
SHF_ALLOC
0x2
Occupies memory during process execution. This attribute is off if a control section does not reside in the memory image of the object file.
SHF_EXECINSTR
0x4
Contains executable machine instructions.
SHF_MASKPROC
0xf0000000
Reserved for processor-specific semantics.
info
Extra information. The interpretation of this information depends on the section type, as described in Table 3-3Table 3-3.
link
Section header table index link. The interpretation of this information depends on the section type, as described in Table 3-3Table 3-3.
name
Specifies the section name. An index into the section header string table section specifies the location of a null-terminated string.
offset
Specifies the byte offset from the beginning of the file to the first byte in the section.
Note -
If the section type is SHT_NOBITS, offset specifies the conceptual placement of the file.
size
Specifies the size of the section in bytes.
Note -
If the section type is SHT_NOBITS, size may be non-zero; however, the section still occupies no space in the file.
type
Categorizes the section contents and semantics. Table 3-3Table 3-3 describes the section types.
Table 3-3
Name
Value
Description
Interpretation by
info
link
null
0
Marks section header as inactive.
progbits
1
Contains information defined explicitly by the program.
symtab
2
Contains a symbol table for link editing. This table may also be used for dynamic linking; however, it may contain many unnecessary symbols.
Note: Only one section of this type is allowed in a file
One greater than the symbol table index of the last local symbol.
The section header index of the associated string table.
strtab
3
Contains a string table. A file may have multiple string table sections.
rela
4
Contains relocation entries with explicit addends. A file may have multiple relocation sections.
The section header index of the section to which the relocation applies.
The section header index of the associated symbol table.
hash
5
Contains a symbol rehash table.
0
The section header index of the symbol table to which the hash table applies.
dynamic
6
Contains dynamic linking information.
0
The section header index of the string table used by entries in the section.
note
7
Contains information that marks the file.
nobits
8
Contains information defined explicitly by the program; however, a section of this type does not occupy any space in the file.
rel
9
Contains relocation entries without explicit addends. A file may have multiple relocation sections.
shlib
10
Reserved.
dynsym
11
Contains a symbol table with a minimal set of symbols for dynamic linking.
loproc
hiproc
0x70000000
0x7fffffff
Lower and upper bound of range reserved for processor-specific semantics.
louser
hiuser
0x80000000
0xffffffff
Lower and upper bound of range reserved for application programs.
Note: Section types in this range may be used by an application without conflicting with system-defined section types.
Note -
Some section header table indexes are reserved and the object file will not contain sections for these special indexes.
