SPARC Assembly Language Reference Manual
E.2.4 Deleted Instructions
Table E-8
Coprocessor loads and stores
RDTBR and WRTBR
TBR no longer exists. It is replaced by TBA, which can be read/written with RDPR/WRPR instructions
RDWIM and WRWIM
WIM no longer exists. WIM has been replaced by several register-window registers
REPSR and WRPSR
PSR no longer exists. It has been replaced by several separate registers that are read/written with other instructions
RETT
Return from trap (replace by DONE/RETRY)
STDFQ
Store Double from Floating-point Queue (replaced by the RDPR FQ instruction
