Contact American Megatrends to get the optional megamgr configuration utility.
The MegaRAID controller cannot be configured by editing the /kernel/drv/mega.conf file.
Follow this procedure to configure and use more than one logical drive. If the /kernel/drv/sd.conf file is not carefully edited, the system may panic upon reboot.
Press Control-M while the system is starting up to configure the controller and all logical drives.
Install the Solaris software and reboot.
You will only see a single logical drive available during installation.
Open /kernel/drv/sd.conf and add additional drives by duplicating the existing entry for target=0 and incrementing the lun field by one for each additional logical drive you want the Solaris software to recognize.
For example, if you have a total of three logical drives configured on your adapter, you would add the following lines:
name="sd" class="scsi"
target=0 lun=1;
target=0 lun=2;
Reboot.
After the system reboots, you can use additional drives.
