Selected AD1848-based devices are supported by the sbpro device driver. Some audio devices based on other compatible chips are also supported.
Although many audio devices claim to be compatible with other audio devices, they are not always compatible at the hardware level and are not supported by the Solaris software. "Tested Compatible Devices" shows which devices have been tested with the Solaris operating environment.
Some cards based on the AD1848 or compatible chips also support advanced audio features that the sbpro driver does not currently support.
The following AD1848 and compatible devices have been tested:
Compaq Deskpro XL Business Audio with built-in AD1847 chip
Turtle Beach Tropez card with CS4231 chip
Some other 100 percent hardware-compatible devices may also function using the sbpro driver; however, they have not been tested or certified with the Solaris operating environment.
The Turtle Beach Tropez card may interfere with the operation of other ISA devices in the system, such as the 3Com 3C509 and SMC Elite 16 Ethernet adapters. If installing a Tropez card in the system causes such devices to fail, run the configuration program that came with the device to select a different I/O base address for the card.
