Set the connector type; use DB-15 or 10BASE-T RJ-45.
Use the splitter cable (shipped with the DualPort ENET controller) with DB-15 connectors.
If the DualPort ENET card is used to install the Solaris software over a network, connect the RJ-45 connector to the first network port (Port 1).
The default setting (DB-9) on the NetFlex-2 ENET-TR needs to be changed.
Compaq NetFlex-2 ENET-TR card only: Configure this card to use a 10-Mbps data rate, not the default (16 Mbps).
