Install the Solaris software.
Modify the driver configuration file /platform/i86pc/kernel/drv/cnft.conf.
This file specifies the valid configurable parameters for the driver:
duplex_mode: This property forces the duplex mode for the controller. It can be set to:
0 - Autoconfigure (Default)
1 - Half duplex
2 - Full duplex
media_speed: This property sets the media speed for the controller. This option can be used to force the 10/100BASE-TX to 10- or 100-Mbps operation. The media speed is autoconfigured by default. The valid values are:
10 - Force 10-Mbps media speed
100 - Force 100-Mbps media speed
max_tx_lsts, max_rx_lsts, tx_threshold: These properties tune driver performance. The valid values are:
Property |
Valid Values |
Default Value |
max_tx_lsts |
4 to 16 |
16 |
max_rx_lsts |
4 to 16 |
16 |
tx_threshold |
2 to 16 |
16 |
debug_flag: Set this property to 1 or 0 to enable or disable debug messages from the driver. Debug messages are disabled by default.
mediaconnector: Set to 1 to enable the AUI interface for the Integrated NetFlex-3 controller on ProLiant 2500 systems or to enable the BNC interface on the Integrated NetFlex-3 controller on the ProLiant 800, Deskpro 4000/6000, and Professional Workstation 5000. The UTP interface is the default (0).
board_id: Set this property to support additional EISA/PCI controllers. The format of the board_id is 0xVVVVDDDD, where VVVV means vendor ID and DDDD, device ID. More than one ID can be specified, if required.
To activate the configuration changes, as root type:
# touch /reconfigure # reboot |
