Solaris 7 (Intel Platform Edition) Device Configuration Guide
Known Problems and Limitations
If you want to change the RAID configuration, first delete the old configuration information using the EISA configuration utility. If you physically move the disks before deleting the RAID configuration (or the partition information on the logical drives), you may not be able to boot your system.
