Reboot the system with Solaris 7 (Intel Platform Edition) Device Configuration Assistant Boot Diskette.
If all other devices have been found by selective scanning, select View/Edit Devices from the Device Tasks menu and manually add the name of the problem device.
The program should warn you if there is a conflict.
When the scan is successful, go to the Boot Solaris menu and select a device to boot from.
If you plan to boot or install from a CD-ROM, select CD.
If you plan to boot or install using the network and your machine is registered as a netinstall client, select NET.
If you plan to boot from the machine's installed hard disk, select DISK.
If the device hangs again when attempting to go the Boot Solaris menu or the device does not function, contact your support provider.
