Follow the manufacturer's documentation and use the manufacturer's setup software to configure the card.
Auto 16/4 and Turbo 16/4 Token Ring adapters in ISA systems only: Run the LANAID program that comes with the adapter.
Set up the Token Ring so that:
The first station has autosense DISABLED.
All other stations can have autosense ENABLED.
When the "Ring speed listening" feature is tested, make sure the Autosense parameter is turned on.
