Solaris 7 (Intel Platform Edition) Device Configuration Guide
Supported Settings
Primary controller:
o IRQ Level:
14
o I/O Address:
0x1F0
Secondary controller:
o IRQ Level:
15
o I/O Address:
0x170
If an IDE CD-ROM drive is installed, the system BIOS parameter for that device should be:
o Drive Type:
Not installed
If an enhanced IDE drive is installed, set the system BIOS as follows:
o Enhanced IDE Drive:
Enabled
Note -
If the BIOS supports autoconfiguration, use this facility to set the number of heads, cylinders, and sectors for the IDE hard disk drive. If this capability is not supported by the BIOS, use the settings provided by the disk manufacturer.
