Consult the Configuration Assistant for address space, I/O space, and IRQs already used by system devices.
Insert the PC Card adapter.
Install the Solaris software, including the PCMCIA packages in the SUNWpcmc cluster.
If you choose to install the Entire Distribution, the PCMCIA packages are automatically included. After installation and reboot, any reconfiguration is done automatically.
If you choose any other distribution, such as the End User Distribution, select Customize from the choices at the bottom of the Software Selection screen. Then choose PCMCIA Support from the scrolling list on the Customize Software screen. After installation and reboot, any reconfiguration is done automatically.
Reboot the system.
