Solaris 7 (Intel Platform Edition) Device Configuration Guide
- Previous: Preconfiguration Information
- Next: Symbios Logic (also NCR) 53C810, 53C810A, 53C815, 53C820, 53C825, 53C825A, 53C860, 53C875, 53C875J, 53C876, 53C895 HBAs
Configuration Procedure
Boot DOS from the diskette drive.
Insert a copy of the DPT Utility diskette in the diskette drive.
Type DPTFMT and press Enter.
Press Enter to begin, and again to continue.
Press <F3> to enter SCSI ID 0 and LUN 0, and press <F3> to continue.
Use the down arrow to select MS-DOS and PC DOS.
Press Enter to write out the drive geometry, and press Enter to reboot.
Insert the user copy diskette of the ECU (CF.EXE) containing the !DPTxxx.CFG files.
At the A:> prompt, type CFG and press Enter.
At the Viewer Edit Details screen, press Enter.
Press the down arrow to the DPT SCSI HBA to select parameters and set them as follows:
o Bus:
Enabled
o IDE Boot Address:
Primary
o Option ROM Address:
Default
o SCSI ID HBA:
Default 7
o WD1003:
Emulation off for both drive 0 and 1
Press <F10> to save your changes.
Insert a copy of the boot diskette.
Press Enter to reboot DOS.
- © 2010, Oracle Corporation and/or its affiliates
