Solaris 7 (Intel Platform Edition) Device Configuration Guide
Known Problems and Limitations
The ISA version IBM Token Ring and compatible adapters will not work in a system that contains a Sound Blaster card configured at the default I/O port address (0x220). If possible, move the Sound Blaster card to port address 0x240; otherwise, remove the Sound Blaster device from the system.
