Configure the 3C509 (ISA bus) adapter for EISA addressing when installed in an EISA bus system.
EtherLink III 3C59x and 3C509B adapters only:
o Media Type: |
Auto Select |
3C509B cards with the following information printed on the card won't work with the Solaris operating environment: ASSY 03-0021-000, REV A.
3C509 Plug and Play EtherLink cards can lock up at "Setting default interfaces for multicast" on a reboot. If this happens, turn the machine off and on or use the Configuration Assistant.
