Install the Solaris software, including the PCMCIA packages in the SUNWpcmc cluster.
Boot the system.
Insert the PC Card ATA device.
If you insert a PC Card ATA device and it isn't recognized (no special files are created), use the prtconf command to try to identify the problem.
Run the prtconf -D command to see if your pcata card is recognized.
A recognized device will appear at the end of the prtconf output. For example:
# prtconf -D . . . pcic, instance #0 (driver name: pcic) . . . disk, instance #0 |
If pcata does not appear in the prtconf output, there is a problem with the PC Card adapter configuration or with the hardware.
Check to see whether the problem is with the card or the adapter by trying to use the card on another machine and by seeing if it works on the same machine using DOS.
For PC Card devices, nodes are created in /devices that include the socket number as one component of a device name that the node refers to. However, the /prtc/dev names and the names in /dev/dsk and /dev/rdsk do follow the current convention for ATA devices, which do not encode the socket number in any part of the name. See the pcata(7D) man page.
If you want to remove the disk, you must unmount the file system.
If you want to create a pcfs file system, use a DOS machine. To mount a pcfs file system, type:
| # mount -F pcfs /dev/dsk/c#d#p0:c /mnt |
For more information, see the pcfs(7FS) and mount(1M) man pages.
If you want to create a ufs file system, use the newfs command and type:
| # newfs /dev/rdsk/c#d#s# |
To mount a ufs file system, type:
| # mount -F ufs /dev/dsk/c#d#s# /mnt |
For more information, see the newfs(1M) andmount(1M) man pages.
To create a Solaris partition, run the format command and go to the Partition menu. For more information, see the format(1M) man page.
