Multithreaded Programming Guide
Producer/Consumer Problem Example
Example 9-2 shows the producer/consumer problem with the producer and consumer in separate processes. The main routine maps zero-filled memory (that it shares with its child process) into its address space. Note that mutex_init() and cond_init() must be called because the type of the synchronization variables is USYNC_PROCESS.
A child process is created that runs the consumer. The parent runs the producer.
This example also shows the drivers for the producer and consumer. The producer_driver() simply reads characters from stdin and calls producer(). The consumer_driver() gets characters by calling consumer() and writes them to stdout.
The data structure for Example 9-2 is the same as that used for the solution with condition variables (see "Nested Locking with a Singly Linked List").
Example 9-2 The Producer/Consumer Problem, Using USYNC_PROCESS
main() {
    int zfd;
    buffer_t *buffer;
    zfd = open("/dev/zero", O_RDWR);
    buffer = (buffer_t *)mmap(NULL, sizeof(buffer_t),
        PROT_READ|PROT_WRITE, MAP_SHARED, zfd, 0);
    buffer->occupied = buffer->nextin = buffer->nextout = 0;
    mutex_init(&buffer->lock, USYNC_PROCESS, 0);
    cond_init(&buffer->less, USYNC_PROCESS, 0);
    cond_init(&buffer->more, USYNC_PROCESS, 0);
    if (fork() == 0)
        consumer_driver(buffer);
    else
        producer_driver(buffer);
void producer_driver(buffer_t *b) {
    int item;
    while (1) {
        item = getchar();
        if (item == EOF) {
            producer(b, `\0');
            break;
        } else
            producer(b, (char)item);
void consumer_driver(buffer_t *b) {
    char item;
    while (1) {
        if ((item = consumer(b)) == '\0')
            break;
        putchar(item);
A child process is created to run the consumer; the parent runs the producer.
