Example 4-17 shows the producer/consumer problem with the producer and consumer in separate processes. The main routine maps zero-filled memory (that it shares with its child process) into its address space.
A child process is created that runs the consumer. The parent runs the producer.
This example also shows the drivers for the producer and consumer. The producer_driver() simply reads characters from stdin and calls producer(). The consumer_driver() gets characters by calling consumer() and writes them to stdout.
The data structure for Example 4-17 is the same as that used for the condition variables example (see Example 4-4). Two semaphores represent the number of full and empty buffers and ensure that producers wait until there are empty buffers and that consumers wait until there are full buffers.
main() {
int zfd;
buffer_t *buffer;
pthread_mutexattr_t mattr;
pthread_condattr_t cvattr_less, cvattr_more;
zfd = open("/dev/zero", O_RDWR);
buffer = (buffer_t *)mmap(NULL, sizeof(buffer_t),
PROT_READ|PROT_WRITE, MAP_SHARED, zfd, 0);
buffer->occupied = buffer->nextin = buffer->nextout = 0;
pthread_mutex_attr_init(&mattr);
pthread_mutexattr_setpshared(&mattr,
PTHREAD_PROCESS_SHARED);
pthread_mutex_init(&buffer->lock, &mattr);
pthread_condattr_init(&cvattr_less);
pthread_condattr_setpshared(&cvattr_less, PTHREAD_PROCESS_SHARED);
pthread_cond_init(&buffer->less, &cvattr_less);
pthread_condattr_init(&cvattr_more);
pthread_condattr_setpshared(&cvattr_more,
pthread_cond_init(&buffer->more, &cvattr_more);
if (fork() == 0)
consumer_driver(buffer);
else
producer_driver(buffer);
void producer_driver(buffer_t *b) {
int item;
while (1) {
item = getchar();
if (item == EOF) {
producer(b, `\0');
break;
} else
producer(b, (char)item);
void consumer_driver(buffer_t *b) {
char item;
while (1) {
if ((item = consumer(b)) == '\0')
break;
putchar(item);
