Multithreaded Programming Guide
Enable or Disable Cancellation
pthread_setcancelstate(3T)
Use pthread_setcancelstate(3T) to enable or disable thread cancellation. When a thread is created, thread cancellation is enabled by default.
Prototype:
int	pthread_setcancelstate(int state, int *oldstate);
#include <pthread.h>
int oldstate;
int ret;
/* enabled */
ret = pthread_setcancelstate(PTHREAD_CANCEL_ENABLE, &oldstate);
/* disabled */
ret = pthread_setcancelstate(PTHREAD_CANCEL_DISABLE, &oldstate);
Return Values
pthread_setcancelstate() returns zero after completing successfully. Any other returned value indicates that an error occurred. When the following condition occurs, the pthread_setcancelstate() function fails and returns the corresponding value.
EINVAL
The state is not PTHREAD_CANCEL_ENABLE or PTHREAD_CANCEL_DISABLE.
