System Interface Guide
Dynamic libraries
Unlike the static libraries, shared libraries do separate the application programming interface from the implementation. The interface is bound to an implementation of the library only at runtime. This allows SunSoft to evolve the library's implementation - such as changing internal interfaces, while maintaining the API and preserving binary compatibility with applications built against it.
