The most significant element in scheduling behavior for realtime applications is the provision of a real-time scheduling class. The standard time-sharing scheduling class is not suitable for realtime applications because this scheduling class treats every process equally and has a limited notion of priority. Realtime applications require a scheduling class in which process priorities are taken as absolute and are changed only by explicit application operations.
The term dispatch latency describes the amount of time it takes for a system to respond to a request for a process to begin operation. With a scheduler written specifically to honor application priorities, realtime applications can be developed with a bounded dispatch latency.
Figure 9-2 illustrates the amount of time it takes an application to respond to a request from an external event.
The overall application response time is composed of the interrupt response time, the dispatch latency, and the time it takes the application itself to determine its response.
The interrupt response time for an application includes both the interrupt latency of the system and the device driver's own interrupt processing time. The interrupt latency is determined by the longest interval that the system must run with interrupts disabled; this is minimized in SunOS 5.0 through 5.7 using synchronization primitives that do not commonly require a raised processor interrupt level.
During interrupt processing, the driver's interrupt routine wakes up the high priority process and returns when finished. The system detects that a process with higher priority than the interrupted process in now dispatchable and arranges to dispatch that process. The time to switch context from a lower priority process to a higher priority process is included in the dispatch latency time.
Figure 9-3 illustrates the internal dispatch latency/application response time of a system, defined in terms of the amount of time it takes for a system to respond to an internal event. The dispatch latency of an internal event represents the amount of time required for one process to wake up another higher priority process, and for the system to dispatch the higher priority process.
The application response time is the amount of time it takes for a driver to wake up a higher priority process, have a low priority process release resources, reschedule the higher priority task, calculate the response, and dispatch the task.
Interrupts can arrive and be processed during the dispatch latency interval. This processing increases the application response time, but is not attributed to the dispatch latency measurement, and so is not bounded by the dispatch latency guarantee.
With the new scheduling techniques provided with realtime SunOS 5.0 through 5.7, the system dispatch latency time is within specified bounds. As you can see in the table below, dispatch latency improves with a bounded number of processes.
Table 9-1 Realtime System Dispatch Latency with SunOS 5.0 through 5.7| Workstation | Bounded Number of Processes | Arbitrary Number of Processes |
| SPARCstation 2 | <0.5 milliseconds in a system with fewer than 16 active processes | 1.0 milliseconds |
| SPARCstation 5 | <0.3 millisecond | 0.3 millisecond |
| Ultra 1-167 | <0.15 millisecond | <0.15 millisecond |
Tests for dispatch latency and experience with such critical environments as manufacturing and data acquisition have proven that the Sun workstation is an effective platform for the development of realtime applications. (We apologize that the examples are not of current products.)
The SunOS 5.0 through 5.7 kernel dispatches processes by priority. The scheduler (or dispatcher) supports the concept of scheduling classes. Classes are defined as Realtime (RT), System (sys), and Time-Sharing (TS). Each class has a unique scheduling policy for dispatching processes within its class.
The kernel dispatches highest priority processes first. By default, realtime processes have precedence over sys and TS processes, but administrators can configure systems so that TS and RT processes have overlapping priorities.
Figure 9-4 illustrates the concept of classes as viewed by the SunOS 5.0 through 5.7 kernel.
At highest priority are the hardware interrupts; these cannot be controlled by software. The interrupt processing routines are dispatched directly and immediately from interrupts, without regard to the priority of the current process.
Realtime processes have the highest default software priority. Processes in the RT class have a priority and time quantum value. RT processes are scheduled strictly on the basis of these parameters. As long as an RT process is ready to run, no sys or TS process can run. Fixed priority scheduling allows critical processes to run in a predetermined order until completion. These priorities never change unless an application changes them.
An RT class process inherits the parent's time quantum, whether finite or infinite. A process with a finite time quantum runs until the time quantum expires or the process terminates, blocks (while waiting for an I/O event), or is preempted by a higher priority runnable realtime process. A process with an infinite time quantum ceases execution only when it terminates, blocks, or is preempted.
The sys class exists to schedule the execution of special system processes, such as paging, STREAMS, and the swapper. It is not possible to change the class of a process to the sys class. The sys class of processes has fixed priorities established by the kernel when the processes are started.
At lowest priority are the time-sharing (TS) processes. TS class processes are scheduled dynamically, with a few hundred milliseconds for each time slice. The TS scheduler switches context in round-robin fashion often enough to give every process an equal opportunity to run, depending upon its time slice value, its process history (when the process was last put to sleep), and considerations for CPU utilization. Default time-sharing policy gives larger time slices to processes with lower priority.
A child process inherits the scheduling class and attributes of the parent process through fork(2). A process' scheduling class and attributes are unchanged by exec(2).
Different algorithms dispatch each scheduling class. Class dependent routines are called by the kernel to make decisions about CPU process scheduling. The kernel is class-independent, and takes the highest priority process off its queue. Each class is responsible for calculating a process' priority value for its class. This value is placed into the dispatch priority variable of that process.
As Figure 9-5 illustrates, each class algorithm has its own method of nominating the highest priority process to place on the global run queue.
Each class has a set of priority levels that apply to processes in that class. A class-specific mapping maps these priorities into a set of global priorities. It is not required that a set of global scheduling priority maps start with zero, nor that they be contiguous.
By default, the global priority values for time-sharing (TS) processes range from -20 to +20, mapped into the kernel from 0-40, with temporary assignments as high as 99. The default priorities for realtime (RT) processes range from 0-59, and are mapped into the kernel from 100 to 159. The kernel's class-independent code runs the process with the highest global priority on the queue.
The dispatch queue is a linear linked list of processes with the same global priority. Each process is invoked with class specific information attached to it. A process is dispatched from the kernel dispatch table based upon its global priority.
When a process is dispatched, the process' context is mapped into memory along with its memory management information, its registers, and its stack. Then execution begins. Memory management information is in the form of hardware registers containing data needed to perform virtual memory translations for the currently running process.
When a higher priority process becomes dispatchable, the kernel interrupts its computation and forces the context switch, preempting the currently running process. A process can be preempted at any time if the kernel finds that a higher priority process is now dispatchable.
For example, suppose that process A performs a read from a peripheral device. Process A is put into the sleep state by the kernel. The kernel then finds that a lower priority process B is runnable, so process B is dispatched and begins execution. Eventually, the peripheral device interrupts, and the driver of the device is entered. The device driver makes process A runnable and returns. Rather than returning to the interrupted process B, the kernel now preempts B from processing and resumes execution of the awakened process A.
Another interesting situation occurs when several processes contend for kernel resources. When a lower priority process releases a resource for which a higher priority realtime process is waiting, the kernel immediately preempts the lower priority process and resumes execution of the higher priority process.
Priority inversion occurs when a higher priority process is blocked by one or more lower priority processes for a long time. The use of synchronization primitives such as mutual-exclusion locks in the SunOS 5.0 through 5.7 kernel can lead to priority inversion.
A process is blocked when it must wait for one or more processes to relinquish resources. If blocking continues, it can lead to missed deadlines, even for low levels of utilization.
The problem of priority inversion has been addressed for mutual-exclusion locks for the SunOS 5.0 through 5.7 kernel by implementing a basic priority inheritance policy. The policy states that a lower priority process inherits the priority of a higher priority process when the lower priority process blocks the execution of the higher priority process. This places an upper bound on the amount of time a process can remain blocked. The policy is a property of the kernel's behavior, not a solution that a programmer institutes through system calls or function execution. User-level processes can still exhibit priority inversion, however.
There is no mechanism by which processes synchronizing with other processes will automatically inherit the priority of waiting processes. An application can bound its priority inversion by using priority ceiling emulation.
Under this model, the application associates a priority with each synchronization object, which is typically the highest priority of any process that can block on that object.
Each process then uses the following sequence when manipulating the shared resources:
Raise process priority to maximum of current level and synchronization object level
Acquire synchronization object
Execute the critical section
Release synchronized object
Return to previous process priority level
