Under SunOS 5.0 through 5.7, the memory residency of a process is determined by its current state, the total available physical memory, the number of active processes, and the processes' demand for memory. This is appropriate in a time-share environment, but it is often unacceptable for a realtime process. In a realtime environment, a process must guarantee a memory residence for all or part of itself to reduce its memory access and dispatch latency.
For realtime in SunOS 5.0 through 5.7, memory locking is provided by a set of library routines that allow a process running with superuser privileges to lock specified portions of its virtual address space into physical memory. Pages locked in this manner are exempt from paging until they are unlocked or the process exits.
There is a system-wide limit on the number of pages that can be locked at any time. This is a tunable parameter whose default value is calculated at boot time. It is based on the number of page frames less another percentage (currently set at ten percent).
A call to mlock(3C) requests that one segment of memory be locked into the system's physical memory. The pages that make up the specified segment are faulted in and the lock count of each is incremented. Any page with a lock count greater than 0 is exempt from paging activity.
A particular page can be locked multiple times by multiple processes through different mappings. If two different processes lock the same page, the page remains locked until both processes remove their locks. However, within a given mapping, page locks do not nest. Multiple calls of locking functions on the same address by the same process are removed by a single unlock request.
If the mapping through which a lock has been performed is removed, the memory segment is implicitly unlocked. When a page is deleted through closing or truncating the file, it is also unlocked implicitly.
Locks are not inherited by a child process after a fork(2) call is made. So, if a process with memory locked forks a child, the child must perform a memory locking operation in its own behalf to lock its own pages. Otherwise, the child process incurs copy-on-write page faults, which are the usual penalties associated with forking a process.
To unlock a page of memory, a process requests that a segment of locked virtual pages be released by a call to munlock(3C). The lock counts of the specified physical pages are decremented. Once the lock count of a page has been decremented to 0, the page is swapped normally.
A superuser process can request that all mappings within its address space be locked by a call to mlockall(3C). If the flag MCL_CURRENT is set, all the existing memory mappings are locked. If the flag MCL_FUTURE is set, every mapping that is added to or that replaces an existing mapping is locked into memory.
A page is permanently locked into memory when its lock count reaches 65535 (0xFFFF). The value 0xFFFF is implementation defined and might change in future releases. Pages locked in this manner cannot be unlocked. Reboot the system to recover.
