The problems described in this section all increase the response time of the system to varying extents. The degradation can be serious enough to cause an application to miss a critical deadline.
Realtime processing can also significantly impact the operation of aspects of other applications active on a system running a realtime application. Since realtime processes have higher priority, time-sharing processes can be prevented from running for significant amounts of time. This can cause interactive activities, such as displays and keyboard response time, to be noticeably slowed.
System response under SunOS 5.0 through 5.7 provides no bounds to the timing of I/O events. This means that synchronous I/O calls should never be included in any program segment whose execution is time critical. Even program segments that permit very large time bounds must not perform synchronous I/O. Mass storage I/O is such a case, where causing a read or write operation hangs the system while the operation takes place.
A common application mistake is to perform I/O to get error message text from disk. This should be done from an independent nonrealtime process or thread.
Interrupt priorities are independent of process priorities. Prioritizing processes does not carry through to prioritizing the services of hardware interrupts that result from the actions of the processes. This means that interrupt processing for a device controlled by a realtime process is not necessarily done before interrupt processing for another device controlled by a timeshare process.
Time-sharing processes can save significant amounts of memory by using dynamically linked, shared libraries. This type of linking is implemented through a form of file mapping. Dynamically linked library routines cause implicit reads.
Realtime programs can use shared libraries, yet avoid dynamic binding, by setting the environment variable LD_BIND_NOW to a non-NULL value when the program is invoked. This forces all dynamic linking to be bound before the program begins execution. See the Linker and Libraries Guide for more information.
A time-sharing process can block a realtime process by acquiring a resource that is required by a realtime process. Priority inversion is a condition that occurs when a higher priority process is blocked by a lower priority process. The term blocking describes a situation in which a process must wait for one or more processes to relinquish control of resources. If this blocking is prolonged, even for lower level resources, deadlines might be missed.
By way of illustration, consider the case in Figure 9-1 where a high priority process wanting to use a shared resource gets blocked when a lower priority process holds the resource, and the lower priority process is preempted by an intermediate priority process. This condition can persist for a long time, arbitrarily long, in fact, since the amount of time the high priority process must wait for the resource depends not only on the duration of the critical section being executed by the lower priority process, but on the duration until the intermediate process blocks. Any number of intermediate processes can be involved.
A page is permanently locked into memory when its lock count reaches 65535 (0xFFFF). The value 0xFFFF is implementation-defined and might change in future releases. Pages locked this way cannot be unlocked.
