To asynchronously await connections, a process first establishes a non-blocking endpoint bound to a service address. When either the result of poll(2) or an asynchronous notification indicates that a connection request has arrived, the process can get the connection request by using the t_listen(3N) function. To accept the connection, the process uses the t_accept(3N) function. The responding endpoint must be separately configured for asynchronous data transfers.
The following example illustrates how to request a connection asynchronously.
#include <tiuser.h> int fd; struct t_call *call; fd = .../* establish a non-blocking endpoint */ call = (struct t_call *) t_alloc(fd, T_CALL, T_ADDR); .../* initialize call structure */ t_connect(fd, call, call); /* connection request is now proceeding asynchronously */ .../* receive indication that connection has been accepted */ t_rcvconnect(fd, &call);
The following example illustrates listening for connections asynchronously.
#include <tiuser.h> int fd, res_fd; struct t_call call; fd = ... /* establish non-blocking endpoint */ .../*receive indication that connection request has arrived */ call = (struct t_call *) t_alloc(fd, T_CALL, T_ALL); t_listen(fd, &call); .../* determine whether or not to accept connection */ res_fd = ... /* establish non-blocking endpoint for response */ t_accept(fd, res_fd, call);
