The STREAMS interface under SunOS 5.0 through 5.7x provides a mechanism for passing an open file descriptor from one process to another. The process with the open file descriptor uses the ioctl(2) function with a command argument of I_SENDFD. The second process obtains the file descriptor by calling the ioctl() function with a command argument of I_RECVFD.
In this example, the parent process prints out information about the test file, and creates a pipe. Next, the parent creates a child process, which opens the test file, and passes the open file descriptor back to the parent through the pipe. The parent process then displays the status information on the new file descriptor.
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <stropts.h>
#include <stdio.h>
#define TESTFILE "/dev/null"
main(int argc, char *argv[])
int fd;
int pipefd[2];
struct stat statbuf;
stat(TESTFILE, &statbuf);
statout(TESTFILE, &statbuf);
pipe(pipefd);
if (fork() == 0) {
close(pipefd[0]);
sendfd(pipefd[1]);
} else {
close(pipefd[1])
recvfd(pipefd[0]);
sendfd(int p)
int tfd;
tfd = open(TESTFILE, O_RDWR);
ioctl(p, I_SENDFD, tfd);
recvfd(int p)
struct strrecvfd rfdbuf;
char fdbuf[32];
ioctl(p, I_RECVFD, &rfdbuf);
fstat(rfdbuf.fd, &statbuf);
sprintf(fdbuf, "recvfd=%d", rfdbuf.fd);
statout(fdbuf, &statbuf);
statout(char *f, struct stat *s)
printf("stat: from=%s mode=0%o, ino=%ld, dev=%lx, rdev=%lx\n",
f, s->st_mode, s->st_ino, s->st_dev, s->st_rdev);
fflush(stdout);
