To lock an entire file, set the offset to zero and set the size to zero.
There are several ways to set a lock on a file. Choice of method depends on how the lock interacts with the rest of the program, performance, and portability. This example uses the POSIX standard-compatible fcntl(2) function. It tries to lock a file until one of the following happens:
The file is successfully locked
There is an error
MAX_TRY is exceeded, and the program gives up trying to lock the file
#include <fcntl.h>
struct flock lck;
lck.l_type = F_WRLCK; /* setting a write lock */
lck.l_whence = 0; /* offset l_start from beginning of file */
lck.l_start = (off_t)0;
lck.l_len = (off_t)0; /* until the end of the file */
if (fcntl(fd, F_SETLK, &lck) <0) {
if (errno == EAGAIN || errno == EACCES) {
(void) fprintf(stderr, "File busy try again later!\n");
return;
perror("fcntl");
exit (2);
Using fcntl(2), you can set the type and start of the lock request by setting a few structure variables.
Mapped files cannot be locked with flock(3B). See mmap(2). However, the multithread oriented synchronization mechanisms (in either POSIX or Solaris styles) can be used with mapped files. See mutex(3T), condition(3T), semaphore(3T), and rwlock(3T).
