Advanced file I/O functions create and remove directories and files, create links to existing files, and obtain or modify file status information.
Table 6-2 Advanced File I/O Functions| Function Name | Purpose |
| link(2) | Link to a file |
| access(2) | Determine accessibility of a file |
| mknod(2) | Make a special or ordinary file |
| chmod(2) | Change mode of file |
| chown(2), lchown(2), fchown(2) | Change owner and group of a file |
| utime(2) | Set file access and modification times |
| stat(2), lstat(2), fstat(2) | Get file status |
| fcntl(2) | Perform file control functions |
| ioctl(2) | Control device |
| fpathconf(2) | Get configurable path name variables |
| opendir(3C), readdir(3C), closedir(3C) | Perform directory operations |
| mkdir(2) | Make a directory |
| readlink(2) | Read the value of a symbolic link |
| rename(2) | Change the name of a file |
| rmdir(2) | Remove a directory |
| symlink(2) | Make a symbolic link to a file |
