Java programs are written in two forms: applications and applets.
Java applications are run by invoking the Java interpreter from the command line and specifying the file containing the compiled application.
Java applets are invoked from a browser. The HTML code interpreted by the browser names a file containing the compiled applet. This causes the browser to invoke the Java interpreter which loads and runs the applet.
Example 2-1 is the source of an application that simply displays "Hello World" on stdout. The method accepts arguments in the invocation, but does nothing with them.
// HelloWorld Application
class HelloWorldApp{
public static void main (String args[]) {
System.out.println ("Hello World");
Note that, like C, the method, or function, to be initially executed is identified as main. The keyword public lets the method be run by anyone; static makes main refer to the class HelloWorldApp and no other instance of the class; void says that main returns nothing; and args[] declares an array of type String.
The application is compiled by
$ javac HelloWorldApp.java
It is run by
$ java HelloWorldApp arg1 arg2 ...
Example 2-2 is the source of the applet which is equivalent to the application in Example 2-1.
// HelloWorld Applet
import java.awt.Graphics;
import java.applet.Applet;
public class HelloWorld extends Applet {
public void paint (Graphics g) {
g.drawString ("Hello World", 25, 25);
In an applet, all referenced classes must be explicitly imported. The keywords public and void mean the same as in the application; extends says that the class HelloWorld inherits from the class Applet.
The applet is compiled by
$ javac HelloWorld.java
The applet is invoked in a browser by HTML code. A minimum HTML page to run the applet is:
<title>Test</title> <hr> <applet code="HelloWorld.class" width=100 height=50> </applet> <hr>
