The priocntl(1) utility performs four different control functions on the scheduling of a process:
priocntl -l |
displays configuration information. |
priocntl -d |
displays the scheduling parameters of processes. |
priocntl -s |
sets the scheduling parameters of processes. |
priocntl -e |
executes a command with the specified scheduling parameters. |
The following are some examples of using priocntl.
The output of the -l option for the default configuration is.
$ priocntl -d -i all CONFIGURED CLASSES ================== SYS (System Class) TS (Time Sharing) Configured TS User Priority Range -20 through 20 RT (Real Time) Maximum Configured RT Priority: 59 |
An example of displaying information on all processes
An example of displaying information on all time-sharing processes
$ priocntl -d -i class TS |
An example of displaying information on all processes with user ID 103 or 6626
$ priocntl -d -i uid 103 6626 |
An example of making the process with ID 24668 a real-time process with default parameters
$ priocntl -s -c RT -i pid 24668 |
An example of making 3608 RT with priority 55 and a one-fifth second time slice.
$ priocntl -s -c RT -p 55 -t 1 -r 5 -i pid 3608 |
An example of changing all processes into time-sharing processes
$ priocntl -s -c TS -i all |
For uid 1122, reduce TS user priority and user priority limit to -10
$ priocntl -s -c TS -p -10 -m -10 -i uid 1122 |
An example of starting a real-time shell with default real-time priority
$ priocntl -e -c RT /bin/sh |
An example of running make with a time-sharing user priority of -10.
$ priocntl -e -c TS -p -10 make bigprog |
The priocntl command subsumes the function of nice. nice works only on time-sharing processes and uses higher numbers to assign lower priorities. The example above is equivalent to using nice to set an "increment" of 10
$ nice -10 make bigprog |
