POSIX semaphores are much lighter weight than are System V semaphores. A POSIX semaphore structure defines a single semaphore, not an array of up to twenty five semaphores.
The POSIX semaphore interfaces are
sem_open(3R) |
Connects to, and optionally creates, a named semaphore; |
sem_init(3R) |
Initializes a semaphore structure (internal to the calling program, so not a named semaphore). |
sem_close(3R) |
Ends the connection to an open semaphore. |
sem_unlink(3R) |
Ends the connection to an open semaphore and causes the semaphore to be removed when the last process closes it. |
sem_destroy(3R) |
sem_getvalue(3R) |
Copies the value of the semaphore into the specified integer. |
sem_wait(3R), sem_trywait(3R) |
Blocks while the semaphore is held by other processes or returns an error if the semaphore is held by another process. |
sem_post(3R) |
Increments the count of the semaphore. |
