Many of the I/O methods in the API will throw an IOException for any condition that causes the operation to fail. The underlying NFS classes throw a subclass of IOException called NFSException that conveys more detailed information about the failure in an error code within the Exception object. For instance, the NFS exception will indicate whether a write failed because the file system is exported read-only, or because there is no space left on the disk. While an application that knows it is accessing an NFS file can cast the IOException to an NFSException and obtain the NFS-specific error code, there is yet no file system independent mechanism that will allow an application to obtain a common set of error codes for all file system types. The NFS error codes will be documented in the next release of the NFS classes.
