When a message arrives to your application, the following occurs:
The file descriptor becomes active.
The Xt main loop breaks out of its select and calls the function registered by the XtAppAddInput call.
The registered function calls tt_message_receive.
The message is read in and any callbacks associated with the message are run.
The message callback returns.
If the message callback returns TT_CALLBACK_PROCESSED
, tt_message_receive returns a value of null to the input callback.
The input callback continues with any other processing.
For example, the following input callback:
input_callback(...) { Tt_message m; printf ("input callback entered\n"); m = tt_message_receive(); printf ("input callback exiting, message handle is %d\n", (int)m); } |
and the following message callback:
message_callback(...) { printf("message callback entered\n"); return TT_CALLBACK_PROCESSED; } |
results in the following output:
input callback entered message callback entered input callback exiting, message handle is 0 |
