What should the tt_db databases contain?
The tt_db databases currently contain the following ten files:
access_table.ind
access_table.rec
file_object_map.ind
file_object_map.rec
file_table.ind
file_table.rec
file_table.var
property_table.ind
property_table.rec
property_table.var
The permissions for these files are set to -rw-r--r-- .
