ToolTalk User's Guide
Is there protection against interception or imitation?
No. The "plug-and-play" concept of the ToolTalk service allows applications to install and deinstall tools of choice that best perform a particular task. If application B responds better to protocol X than does application A, protocol X should be allowed to deinstall application A and install application B.
