All machines should have the SUNWtltk and SUNWdtcor packages installed if they contain files referenced in ToolTalk messages. To confirm that rpc.ttdbserverd is installed on a system:
Login to the system.
Use pkginfo(1) to determine that the SUNWtltk and SUNWdtcor packages are installed.
The /etc/inetd.conf config line below is installed by the SUNWdtcor Solaris package. If a system does not have SUNWtltk installed, you should make sure that SUNWdtcor is present before installing SUNWtltk. Do not copy a Solaris 7 (SunOS 5.7 or compatible) server onto a machine running the Solaris 1.0 (SunOS 4.0/4.1 or compatible) operating system.
Check that the /etc/inetd.conf file contains the following line.
100083/1 tli rpc/tcp wait root /usr/openwin/bin/rpc.ttdbserverd  |
If you find that rpc.ttdbserverd is not present, then you can install it by adding the SUNWtltlk and SUNWdtcor packages using pkgadd(1M). After adding the packages have inetd reread its coniguration file:
# ps -ef | grep inetd # kill -HUP inetd-pid  |
inetd-pid is from the ps listing.
