ToolTalk User's Guide
Scoping to a File in a Session
The type TT_FILE_IN_SESSION scopes to the specified file in the specified session only. A pattern with this scope set will only match messages that are scoped to both the file and the session. Example 3-5 adds the session and then registers the pattern.
Example 3-5 Adding a Session to the TT_FILE_IN_SESSION-Scoped Pattern
Obtain procid
tt_open();
Create pattern
Tt_pattern pat = tt_create_pattern();
Add scope to pattern
tt_pattern_scope_add(pat,TT_FILE_IN_SESSION);
Add file to pattern
tt_pattern_file_add(pat, file);
Add session to pattern
tt_pattern_session_add(pat, tt_default_session());
Register pattern
tt_pattern_register(pat);
Example 3-6 registers the pattern and then joins a session.
Example 3-6 Joining a Session to Set the Session of a TT_FILE_IN_SESSION-Scoped Pattern
Obtain procid
tt_open();
Create pattern
tt_pattern_scope_add(pat, TT_FILE_IN_SESSION);
Add file to pattern
Register pattern
Join session
tt_session_join(tt_default_session());
Example 3-7 sets the scope value for a static pattern.
Example 3-7 Setting the Scope Value for a TT_FILE_IN_SESSION Static Pattern
Obtain procid
tt_open();
Declare Ptype
Tt_ptype_declare(ptype);
Join File
tt_file_join(file);
Join session
