When you have completed your message, use tt_message_send to send it.
If the ToolTalk service returns TT_WRN_STALE_OBJID
, it has found a forwarding pointer in the ToolTalk database that indicates the object mentioned in the message has been moved. However, the ToolTalk service will send the message with the new objid. You can then use tt_message_object to retrieve the new objid from the message and put it into your internal data structure.
If you will not need the message in the future (for example, if the message was a notice), you can use tt_message_destroy to delete the message and free storage space.
If you are expecting a reply to the message, do not destroy the message until you have handled the reply.
