The following listing shows the syntax for an otype file.
otid--object type identifier (otid). Identifies the object type. An otid must be unique for every installation. Because this identifier cannot be changed after installation time, each chosen name must be unique. For example, begin with the ptid of the tool that implements the otype. The otid is limited to 64 characters and should not be one of the reserved identifiers: ptype, otype, start, opnum, queue, file, session, observe, or handle.
The object body portion of the otype definition is a list of osignatures for messages about the object that your application wants to observe and handle.
op--operation name. This name is matched against the op attribute in messages.
If you specify message signatures in both your ptype and otypes, use unique operation names in each. For example, do not specify a display operation in both your ptype and otype.
args--arguments for the operation. If the args list is void, the signature matches only messages with no arguments. If the args list is empty (just "()"), the signature matches messages without regard to the arguments.
contextdcl--context name. When a pattern with this named context is generated from the signature, it contains an empty value list.
ptid--process type identifier for the application that manages this type of object.
opnum--fill in the message's opnum attribute with the specified number to enable you to identify the signature that matched the message.
When the message matches the signature, the opnum from the signature is filled into the message. Your application can then retrieve the opnum with the tt_message_opnum call. By giving each signature a unique opnum, you can quickly determine which signature matched the message.
You can attach a callback routine to the opnum with the tt_otype_opnum_callback_add call. When the message is matched, the ToolTalk service will check for any callbacks attached to the opnum and, if any are found, run them.
inherit--Otypes form an inheritance hierarchy in which operations can be inherited from base types. The ToolTalk service requires the otype definer to explicitly name all inherited operations and the otype from which to inherit. This explicit naming prevents later changes (such as adding a new level to the hierarchy, or adding new operations to base types) from unexpectedly affecting the behavior of an otype.
scope--this pattern attribute is matched against the scope attribute in messages. It appears on the rightmost side of the arrow and is filled in by the ToolTalk service during message dispatch. This means the definer of the otype can specify the attributes instead of requiring the message sender to know how the message should be delivered.
start--if the osignature matches a message and no running process of this otype has a pattern that matches the message, start a process of this otype.
queue--if the osignature matches a message and no running process of this otype has a pattern that matches the message, queue the message until a process of this otype registers a pattern that matches it.
The following listing illustrates an otype file.
The Sun_EditDemo_opnums.h file defines symbolic definitions for all the opnums used by edit.c, allowing both the edit.types file and edit.c file to share the same definitions.
