Solaris 7 (SPARC Platform Edition) Release Notes
cpr_reset_properties: Unable to open /.cpr_default on /pci@1f,4000/scsi@3/disk@0,0 (4163575)
The above-listed message or a variation of this message may be displayed whenever you reboot after a cpr Suspend if the file system logging feature is enabled.
The cpr Suspend/Resume feature does not work with with the logging file system feature when logging is used on either the root file system or the file system chosen for the cpr state file.
The criteria for using cpr are:
Workaround: Select a file system for the cpr state file other than root or one that has logging turned on.
