/* CSA_X_COM_SUPPORT_EXT 拡張を指定して、
* CSA_X_XT_APP_CONTEXT_EXT 拡張と、CSA_X_UI_ID_EXT 拡張が
* サポートされているかどうかをチェックします。
check_support[0].item_code = CSA_X_XT_APP_CONTEXT_EXT;
check_support[0].flags = NULL;
check_support[1].item_code = CSA_X_UI_ID_EXT;
check_support[1].flags = NULL;
logon_exts[1].item_code = CSA_X_COM_SUPPORT_EXT;
logon_exts[1].item_data = 2;
logon_exts[1].item_reference = (CSA_buffer)check_support;
logon_exts[0].extension_flags = CSA_EXT_LAST_ELEMENT;
stat = csa_logon(NULL, &caddr, NULL, NULL, NULL, &cal, logon_exts);
if (stat == CSA_SUCCESS) {
access = (CSA_flags)get_access_ext.item_data;
if (check_support[0].flag & CSA_X_COM_SUPPORTED)
printf("The CSA_X_XT_APP_CONTEXT_EXT extension is supported¥n");
if (check_support[1].flag & CSA_X_COM_SUPPORTED)
printf("The CSA_X_UI_ID_EXT extension is supported¥n");
