日本語文字分類の API を用いたプログラム例を紹介します。前述の文字対応 API の場合と同様に、使用する場合には wchar.h ヘッダファイルを取り込むこと、また setlocale() を処理の最初の段階で呼び出して動作ロケールを適切に設定することが必要です。
例 3-3 では、入力ファイルをワイド文字列として読み込んで入力中の JIS X 0208 ひらがなとカタカナを交換し、JIS X 0208 数字文字は ASCII に変換して出力します。
sun% cat my_charconv.c
* Read lines from a file and convert JIS X 0208 hiragana
* characters to JIS X 0208 katakana characters, and
* vice versa. In addition, JIS X 0208 digit characters
* are converted to the correspondent ones in JIS X 0201
* characters.
* Conversion will stop if the input file reaches EOF.
* It is assumed that each line has at most BUFSIZ - 1
* wide char length.
* Actual conversion is done by my_charconv(), which does
* the followings.
* 1. Get the length of the wide string.
* 2. Convert each wide char from the top
* of the string by applying towctrans().
* (The return value of towctrans() will be
* the same if there's no correspondent char.)
* 3. Write the correspondent wide char to
* original string and output it.
#include <stdio.h>
#include <locale.h>
#include <wchar.h>
#include <wctype.h>
#include <jctype.h>
#include <errno.h>
#define WRET L'¥n'
static int my_charconv(wchar_t *);
int
main(int argc, char *argv[])
wchar_t buf[BUFSIZ];
wchar_t *headp, *nextp;
long retval, total;
setlocale(LC_ALL, "");
total = retval = 0;
while (fgetws(buf, BUFSIZ, stdin) != (wchar_t *)NULL) {
retval = my_charconv(buf);
if (retval == -1) {
perror("my_charconv()");
exit(-1);
fprintf(stdout, "%S", buf);
return (0);
static int
my_charconv(wchar_t *wcp)
size_t wstr_len;
wint_t retval;
int index;
long ret_val;
wstr_len = wcslen(wcp);
for (index = 0; index < wstr_len; index++) {
errno = 0;
if (iswctype((wint_t)wcp[index], wctype("jhira")))
retval = towctrans((wint_t)wcp[index], wctrans("tojkata"));
else if (iswctype((wint_t)wcp[index], wctype("jkata")))
retval = towctrans((wint_t)wcp[index], wctrans("tojhira"));
else if (iswctype((wint_t)wcp[index], wctype("jdigit")))
retval = towctrans((wint_t)wcp[index], wctrans("tojisx0201"));
else
retval = wcp[index];
if (errno != 0)
return (-1);
wcp[index] = (wchar_t)retval;
return (0);
sun% cat file5ひらがなはかたかなに置換されます。
カタカナハヒラガナニ置換サレマス。
漢字、記号、全角alphabetや
JIS X 0201 カナナドハ* 置換 サレマセン*。
sun% cc -o my_charconv my_charconv.c
sun% ./my_charconv < file5
ヒラガナハカタカナニ置換サレマス。
かたかなはひらがなに置換されます。
漢字、記号、全角alphabetヤ
* の部分のカタカナは、半角カタカナになります。
