The following is an example of a MIB containing all types of MIB variables. The MIB also includes tables. When this MIB is run through mibcodegen, it generates the appropriate MIB database and the stub code to build a subagent for this MIB.
DEMO-MIB DEFINITIONS ::= BEGIN IMPORTS OBJECT-TYPE, Counter32, Gauge32 FROM SNMPv2-SMI DisplayString, TimeStamp FROM SNMPv2-TC; mib-2 OBJECT IDENTIFIER ::= { mgmt 1 } sun OBJECT IDENTIFIER ::= { enterprises 42 } demo OBJECT IDENTIFIER ::= { sun 1000 } -- -- Some objects -- demoString OBJECT-TYPE SYNTAX DisplayString MAX-ACCESS read-write STATUS current DESCRIPTION "A read-write object of type String." ::= {demo 1} demoInteger OBJECT-TYPE ::= {demoTable 1} DemoEntry ::= SEQUENCE { demoEntryIndex INTEGER, demoEntryString DisplayString, demoEntryInteger INTEGER, demoEntryOid OBJECT IDENTIFIER } SYNTAX INTEGER { up(1), down(2) } MAX-ACCESS read-write STATUS current DESCRIPTION "A read-write object of type Integer." ::= {demo 2} demoOid OBJECT-TYPE SYNTAX OBJECT IDENTIFIER MAX-ACCESS read-write STATUS current DESCRIPTION "A read-write object of type Oid." ::= {demo 3} -- A table composed of some columns demoTable OBJECT-TYPE SYNTAX SEQUENCE OF DemoEntry MAX-ACCESS not-accessible STATUS current DESCRIPTION "A table." ::= {demo 10} demoEntry OBJECT-TYPE SYNTAX DemoEntry MAX-ACCESS not-accessible STATUS current DESCRIPTION "An entry in the table demoTable." INDEX {demoEntryIndex} demoEntryIndex OBJECT-TYPE SYNTAX INTEGER (1..2147483647) MAX-ACCESS not-accessible STATUS current DESCRIPTION "An index to uniquely identify the entry." ::= {demoEntry 1} demoEntryString OBJECT-TYPE SYNTAX DisplayString MAX-ACCESS read-write STATUS current DESCRIPTION "A read-write column of type String." ::= {demoEntry 2} demoEntryInteger OBJECT-TYPE SYNTAX INTEGER { up(1), down(2) } MAX-ACCESS read-write STATUS current DESCRIPTION "A read-write column of type Integer." ::= {demoEntry 3} demoEntryOid OBJECT-TYPE SYNTAX OBJECT IDENTIFIER MAX-ACCESS read-write STATUS current DESCRIPTION "A read-write column of type Oid." ::= {demoEntry 4} demoTrap TRAP-TYPE ENTERPRISE sun VARIABLES { demoInteger, demoString, demoOid} DESCRIPTION " Trap for testing." ::= 2 demoColdLinkTrap TRAP-TYPE ENTERPRISE snmp DESCRIPTION " Trap for testing." ::= 0 END
