Solaris 7 5/99 Online Release Notes (SUNWrdm)
XGL
Gcache decomp Does Edges Incorrectly For gcache_multi_simple_polygon (1167214)
When an XGL Gcache decomposes a polygon with edges, some edges are rendered incorrectly for xgl_gcache_multi_simple_polygon().
Workaround: Set the XGL_GCACHE_USE_APPL_GEOM to TRUE. Alternately, use xgl_gcache_polygon() instead of xgl_gcache_multi_simple_polygon() and turn off the XGL_GCACHE_SHOW_DECOMP_EDGES when creating the GCACHE context.
Window Size Returned by DGA Behind by One Resize Event (1183134)
With XViewTM (and possibly other tool kits) calling the application's resize_proc() before sending the resize request to the server, the window size returned by DGA is behind by one resize event.
Workaround: Calling XSync() before calling xgl_window_raster_resize() fixes the problem.
