Solaris 7 5/99 Online Release Notes (SUNWrdm)
x86 only: Driver Support
The Solaris operating environment running on an x86 based system currently supports numerous devices based on the ISA and EISA I/O buses. Support for these devices and the device drivers written specifically for them may be removed in a future release.
The following device drivers that support only ISA and EISA devices may be removed in a future release. Note that drivers marked with an asterisk (*) also support PCI devices; these drivers continue to be included in the Solaris operating environment to support PCI devices only.
SCSI Host Bus Adapters, Disk Arrays/RAID Controllers
aic
Adaptec AHA-1510A, AHA-1520A/1522A, AHA-1530P/1532P, AIC-6260, AIC-6360 (ISA)
Creative Labs Sound Blaster 16 SCSI-2 Interface
aha
Adaptec AHA-1540B/1542B, AHA-1540C/1542C, AHA-1540CF/1542CF, AHA-1540CP/1542CP (ISA)
eha
Adaptec AHA-1740/1742A (EISA)
esa
Adaptec AHA-2740/2742, AHA-2740A/2742A, AHA-2740T/2742T, AHA-2740AT/2742AT, AHA-2740W/2742W, AHA-2840A/2842A, AHA-2840VL/2842VL, AIC-7770, AIC-7770 Rev. E (EISA, VLB)
blogic
BusLogic/Mylex BT-440C, BT-445C, BT-445S, BT-542B, BT-545C, BT-545S, BT-742A, BT-746C, BT-747C, BT-747S, BT-757C, BT-757CD, BT-757S (ISA, EISA, VLB)
cpqncr*
Compaq 32-bit Fast-Wide SCSI-2/E, Integrated 32-bit Fast-Wide SCSI-2/E (support removed for EISA only)
csa
Compaq SMART Array Controller (EISA)
smartii*
Compaq SMART-2 EISA Array Controller (support removed for EISA only)
dpt
DPT PM2011, PM2012B, PM2021, PM2022, PM2041, PM2041W, PM2042, PM2042W, PM2122, PM2142W, PM3021, PM3222, PM3222UW, PM3332UW (ISA, EISA)
mlx*
Mylex DAC960E (support removed for EISA only)
trantor
Trantor T348 MiniSCSI Plus Parallel
Adaptec APA-348 MiniSCSI
Ethernet Network Adapters
elx*
3Com EtherLink III (3C509, 3C509B, 3C592 Bus Master, 3C597-TX Bus Master) (support removed for ISA, EISA only)
pcn*
Allied Telesyn AT-1500, AT-1500T-Plus, AT-1500BT-Plus (support removed for ISA only)
AMD PCnet-ISA controller chip
Cabletron E-2210
Microdyne NE2000, NE2500plus
nfe
Compaq NetFlex-2 DualPort ENET, NetFlex-2 ENET-TR Controllers (EISA)
cnft*
Compaq NetFlex-3/E (all models) (support removed for EISA only)
iee
Intel EtherExpress 16, EtherExpress 16TP, EtherExpress 16C (82586) (ISA)
ieef
Intel EtherExpress 32, EtherExpress Flash32, EtherExpress FlashC (82596) (EISA)
Unisys EISA Ethernet controller
Unisys U6000/DT2 integrated Ethernet controller
eepro
Intel EtherExpress PRO (82595), EtherExpress PRO/10+ (82595FX) (ISA)
ieef*
Intel EtherExpress PRO/100 (82556) (support removed for EISA only)
nei
Novell/Eagle Technology NE2000, NE2000plus (ISA)
Accton EN1625, EtherCombo-16
Alta EtherCombo-16 T/C
Kingston KNE2000T+, KNE2002+, KNE2031+, KNE2121+, KNE2121H
National Semiconductor Infomover NE2000plus
Olicom EtherCom ISA/II
Thomas Conrad NE2000
nee
Novell/Eagle Technology NE3200 (EISA)
smce
SMC Elite32 (8033) (EISA)
smceu
SMC Elite32C Ultra (8232) (EISA)
smcf
SMC Ether 10/100 (9232) (EISA)
smc
SMC EtherCard PLUS (8003), EtherCard PLUS Elite (8013), EtherCard PLUS Elite16 (8013), EtherCard Elite16 Ultra (8216), EtherCard Elite32T (8033T), EtherEZ (8416) (ISA)
pe
Xircom Pocket Ethernet Adapter III (PE3 and PE2)
Token Ring Network Adapters
tr
IBM Auto 16/4 Token Ring, Token Ring 16/4 Adapter/A, Turbo 16/4 Token Ring (ISA, EISA)
3Com TokenLink III (3C619, 3C679)
mtok*
Madge Smart 16/4 AT Plus, Smart 16/4 AT PnP, Smart 16/4 EISA, Smart 16/4 ISA Client Plus, Smart 16/4 ISA Client PnP (support removed for ISA, EISA only)
