XGL may be removed in a future release. Starting with the Solaris 7 release, the following warning is generated when a XGL program is compiled:
""#error: "XGL has been declared Obsolete and may not be present in""versions of Solaris after 7.""#define SUNXGL_WARNING_DISABLE (or use -D) to disable this message.""" |
To compile a XGL program, disable the message by adding #define to the program:
# define SUNXGL_WARNING_DISABLE |
or by using the following compiler directive:
-DSUNXGL_WARNING_DISABLE |
