A number of derived types have changed to now represent 64-bit quantities in the 64-bit application environment. This change does not affect 32-bit applications; however, any 64-bit applications that consume or export data described by these types need to be re-evaluated for correctness. An example of this is in applications that directly manipulate the utmp(4) or utmpx(4) files. For correct operation in the 64-bit application environment, you should not attempt to directly access these files. Instead, you should use the getutxent(3C) and related family of functions.
A list of changed derived types is included in Appendix A, Changes in Derived Types.
One problem to be aware of is that a type change in one area might result in an unexpected 64-bit conversion in another area. For example, in the case of a function that previously returned an int and now returns an ssize_t, all the callers need to be checked.
Because a long is 32 bits in the ILP32 model and 64 bits in the LP64 model, there might be cases where what was previously defined as a long is neither appropriate nor necessary. In this case, it might be possible to use a more portable derived type.
Related to this, a number of derived types might have changed under the LP64 data model for the reason stated above. For example, pid_t remains a long in the 32-bit environment, but under the 64-bit environment, a pid_t is an int. For a list of derived types modified for the LP64 compilation environment, see Appendix A, Changes in Derived Types.
